Einleitung
The bottom cover must be removed prior to replacing or repairing any internal parts of the Mr. Coffee TF6 (hot plate, power cord, and water tubes). In the event that the bottom cover breaks or must be replaced, a replacement cover must by obtained from the manufacturer.
Was du brauchst
Facing the bottom of the TF6, carefully pull the two rubber feet out with your hands.
Using a Phillips #1 screwdriver, remove the six 11mm Phillips screws that are holding the bottom cover in place.
