Zum Hauptinhalt wechseln
Mt. Fury Roadmaster Rear Derailleur Replacement
Was du brauchst
  1. Mt. Fury Roadmaster Rear Derailleur Replacement, Rear Derailleur: Schritt 1, Bild 1 von 1
    • Flip the bicycle upside down so that the bicycle rests on the seat and handlebars. The bike should be able to stay standing on its own.
  2. Mt. Fury Roadmaster Rear Derailleur Replacement: Schritt 2, Bild 1 von 2 Mt. Fury Roadmaster Rear Derailleur Replacement: Schritt 2, Bild 2 von 2
    • Locate and remove the main axle nuts (both sides) with a 15mm open-end wrench.
  3. Mt. Fury Roadmaster Rear Derailleur Replacement: Schritt 3, Bild 1 von 2 Mt. Fury Roadmaster Rear Derailleur Replacement: Schritt 3, Bild 2 von 2
    • Pull the chain slack and remove the tire.
  4. Mt. Fury Roadmaster Rear Derailleur Replacement: Schritt 4, Bild 1 von 1
    • Locate and remove the rear phillips head screw on the sprocket to remove one side of chain guard.
  5. Mt. Fury Roadmaster Rear Derailleur Replacement: Schritt 5, Bild 1 von 2 Mt. Fury Roadmaster Rear Derailleur Replacement: Schritt 5, Bild 2 von 2
    • Rotate the derailleur arm forward to access the phillips head screw from the forwardmost sprocket. Remove the screw.
    • Be careful to hold the chain guard in place so the sprocket and washers don't fall out. (Chain guard is highlighted in red).
  6. Mt. Fury Roadmaster Rear Derailleur Replacement: Schritt 6, Bild 1 von 1
    • Locate and loosen the hex bolt that clamps the shifting cable.
  7. Mt. Fury Roadmaster Rear Derailleur Replacement: Schritt 7, Bild 1 von 1
    • Remove mounting screw that attaches the derailleur to the bicycle frame.
  8. Mt. Fury Roadmaster Rear Derailleur Replacement: Schritt 8, Bild 1 von 2 Mt. Fury Roadmaster Rear Derailleur Replacement: Schritt 8, Bild 2 von 2
    • Loosen the shifting cable tension adjustment nut and remove the cable from the derailleur assembly .
Abschluss
To install new derailleur, follow these instructions in reverse order.
6 weitere Personen haben diese Anleitung absolviert.
Cal Poly, Team 1-40, Maness Winter 2014 Mitglied von Cal Poly, Team 1-40, Maness Winter 2014
CPSU-MANESS-W14S1G40
4 Mitglieder
5 Anleitungen geschrieben
2 Kommentare
Directions are simple clear and to the point. Excellent!
Paul J. Baker - Antwort
Now how do you put it back?
Wendy Navarro - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 8
Letzte 30 Tage: 47
Insgesamt: 8,370
