Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Einleitung
If you determine that your tire is flat due to a ruptured or damaged inner tube this guide will help you replace the inner tube.
Werkzeuge
Ersatzteile
Keine Ersatzteile angegeben.
  1. Flip the bicycle upside down so that the bicycle rests on the seat and handlebars. The bike should be able to stay standing on its own.
    • Flip the bicycle upside down so that the bicycle rests on the seat and handlebars. The bike should be able to stay standing on its own.
  2. Using a 15mm wrech, loosen the axial nut.
    • Using a 15mm wrech, loosen the axial nut.
  3. Pull the chain slack and remove the tire. Pull the chain slack and remove the tire.
    • Pull the chain slack and remove the tire.
  4. Insert the flat side of the tire lever between the inside edge of the rim and the seal of the tire. Clip the tire lever to the nearest spoke.
    • Insert the flat side of the tire lever between the inside edge of the rim and the seal of the tire.
    • Clip the tire lever to the nearest spoke.
  5. Insert the second tire lever next to first and slowly slide it along the outside edge of the rim until one side of the tire is off the rim. Insert the second tire lever next to first and slowly slide it along the outside edge of the rim until one side of the tire is off the rim.
    • Insert the second tire lever next to first and slowly slide it along the outside edge of the rim until one side of the tire is off the rim.
  6. Re-insert the first tire lever to hook the opposite seam of the tire and repeat steps 3 through 5.
    • Re-insert the first tire lever to hook the opposite seam of the tire and repeat steps 3 through 5.
  7. Remove the cap from the inner tube, and pull the valve stem out of the rim.
    • Remove the cap from the inner tube, and pull the valve stem out of the rim.
Abschluss
To install new inner tube, follow these instructions in reverse order.
Ein weiterer Nutzer hat diese Anleitung absolviert.
Samantha Rawlins
425 Reputation
3 Anleitungen geschrieben
Cal Poly, Team 1-40, Maness Winter 2014 Mitglied von Cal Poly, Team 1-40, Maness Winter 2014
CPSU-MANESS-W14S1G40
4 Mitglieder
5 Anleitungen geschrieben
Replace also means how to put it back together!
ellik - Antwort
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 4
Letzten 30 Tage: 17
Insgesamt: 3,876
