Einleitung
These will clarify how to change the face plate of the game, step by step.
Was du brauchst
Remove two 6 mm Phillips #2 screws on either side of the On/Off Plate.
Remove the On/Off switch plate and save the screws so you can use them later to put the plate back on.
Gently pull out the battery cartridge and if needed, replace the batteries with 3 AA alkaline batteries.
Starting with the yellow face, insert the metal spudger between the yellow face and the white frame, prying the frame apart.
Insert the metal spudger in the space created by the plastic opening tool between the frame and face of the cube.
Pry the cube face from the frame.
After removing the square plates, you can unscrew the screws underneath.
Remove four 6 mm Phillips #2 screws, located on the sides.
Eine weitere Person hat diese Anleitung absolviert.
