Zum Hauptinhalt wechseln
Munchkin Mozart Magic Cube Frame Removal Replacement
Was du brauchst
  1. Munchkin Mozart Magic Cube Frame Removal Replacement, Face plate: Schritt 1, Bild 1 von 2 Munchkin Mozart Magic Cube Frame Removal Replacement, Face plate: Schritt 1, Bild 2 von 2
    • Remove two 6 mm Phillips #2 screws on either side of the On/Off Plate.
  2. Munchkin Mozart Magic Cube Frame Removal Replacement: Schritt 2, Bild 1 von 1
    • Remove the On/Off switch plate and save the screws so you can use them later to put the plate back on.
  3. Munchkin Mozart Magic Cube Frame Removal Replacement: Schritt 3, Bild 1 von 1
    • Gently pull out the battery cartridge and if needed, replace the batteries with 3 AA alkaline batteries.
  4. Munchkin Mozart Magic Cube Frame Removal Replacement: Schritt 4, Bild 1 von 1
    • Starting with the yellow face, insert the metal spudger between the yellow face and the white frame, prying the frame apart.
  5. Munchkin Mozart Magic Cube Frame Removal Replacement: Schritt 5, Bild 1 von 1
    • Insert the metal spudger in the space created by the plastic opening tool between the frame and face of the cube.
    • Pry the cube face from the frame.
  6. Munchkin Mozart Magic Cube Frame Removal Replacement: Schritt 6, Bild 1 von 1
    • After removing the square plates, you can unscrew the screws underneath.
    • Remove four 6 mm Phillips #2 screws, located on the sides.
  7. Munchkin Mozart Magic Cube Frame Removal Replacement: Schritt 7, Bild 1 von 1
    • Remove the rubber corners by simply pulling them off.
  8. Munchkin Mozart Magic Cube Frame Removal Replacement, Frame Removal: Schritt 8, Bild 1 von 1
    • Remove twenty-four 6 mm Phillips #2 from all 6 sides.
    • Once the screws are removed, gently pull apart the frame.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
USF Tampa, Team 1-4, Sullivan Fall 2015 Mitglied von USF Tampa, Team 1-4, Sullivan Fall 2015
USFT-SULLIVAN-F15S1G4
4 Mitglieder
14 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 17
Insgesamt: 1,688
