Einleitung
This will guide you step by step on how you would replace the plate on the game.
Was du brauchst
Remove two 6 mm Phillips #2 screws on either side of the On/Off Plate.
Remove the On/Off switch plate and save the screws so you can use them later to put the plate back on.
Gently pull out the battery cartridge and if needed, replace the batteries with 3 AA alkaline batteries.
Starting with the yellow face, insert the metal spudger between the yellow face and the white frame, prying the frame apart.
Insert the metal spudger in the space created by the plastic opening tool between the frame and face of the cube.
Pry the cube face from the frame.
After removing the square plates, you can unscrew the screws underneath.
Remove four 6 mm Phillips #2 screws, located on the sides.
Remove twenty-four 6 mm Phillips #2 from all 6 sides.
Once the screws are removed, gently pull apart the frame.
Eine weitere Person hat diese Anleitung absolviert.
