Zum Hauptinhalt wechseln
Munchkin Mozart Magic Cube Sound Button Replacement
Was du brauchst
  1. Munchkin Mozart Magic Cube Sound Button Replacement, Face plate: Schritt 1, Bild 1 von 2 Munchkin Mozart Magic Cube Sound Button Replacement, Face plate: Schritt 1, Bild 2 von 2
    • Remove two 6 mm Phillips #2 screws on either side of the On/Off Plate.
  2. Munchkin Mozart Magic Cube Sound Button Replacement: Schritt 2, Bild 1 von 1
    • Remove the On/Off switch plate and save the screws so you can use them later to put the plate back on.
  3. Munchkin Mozart Magic Cube Sound Button Replacement: Schritt 3, Bild 1 von 1
    • Gently pull out the battery cartridge and if needed, replace the batteries with 3 AA alkaline batteries.
  4. Munchkin Mozart Magic Cube Sound Button Replacement: Schritt 4, Bild 1 von 1
    • Starting with the yellow face, insert the metal spudger between the yellow face and the white frame, prying the frame apart.
  5. Munchkin Mozart Magic Cube Sound Button Replacement: Schritt 5, Bild 1 von 1
    • Insert the metal spudger in the space created by the plastic opening tool between the frame and face of the cube.
    • Pry the cube face from the frame.
  6. Munchkin Mozart Magic Cube Sound Button Replacement: Schritt 6, Bild 1 von 1
    • After removing the square plates, you can unscrew the screws underneath.
    • Remove four 6 mm Phillips #2 screws, located on the sides.
  7. Munchkin Mozart Magic Cube Sound Button Replacement: Schritt 7, Bild 1 von 1
    • Remove the rubber corners by simply pulling them off.
  8. Munchkin Mozart Magic Cube Sound Button Replacement, Sound Button: Schritt 8, Bild 1 von 1
    • Flip the frame over so that green motherboard over so that the LED is face down and the brown side of the motherboard is face up using the Jimmy to remove the glue connecting the motherboard to the white frame.
  9. Munchkin Mozart Magic Cube Sound Button Replacement: Schritt 9, Bild 1 von 1
    • Slide the motherboard out of the frame.
  10. Munchkin Mozart Magic Cube Sound Button Replacement: Schritt 10, Bild 1 von 2 Munchkin Mozart Magic Cube Sound Button Replacement: Schritt 10, Bild 2 von 2
    • To remove the button use your fingers or forceps to remove the gray rubber button piece on the green side of the motherboard.
Abschluss
USF Tampa, Team 1-4, Sullivan Fall 2015 Mitglied von USF Tampa, Team 1-4, Sullivan Fall 2015
USFT-SULLIVAN-F15S1G4
4 Mitglieder
14 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 12
Letzte 30 Tage: 17
Insgesamt: 638
