Einleitung
Display how to remove the battery.
Was du brauchst
Slide the wide plastic opening tool across the seem, separating it if you can't pry the device open using just the spudger.
Use the wide plastic opening tool to slowly pry each side of the battery up.
Fast fertig!
Abschluss
