Zum Hauptinhalt wechseln
Munchkinz LCD Assembly
Was du brauchst
  1. Munchkinz LCD Assembly, Opening Device: Schritt 1, Bild 1 von 1
    • Insert spudger into the USB Micro slot and pry the case apart.
    • Be careful not to go too deep and bend the prong inside the Micro USB port.
  2. Munchkinz LCD Assembly, Pry Device Apart: Schritt 2, Bild 1 von 2 Munchkinz LCD Assembly, Pry Device Apart: Schritt 2, Bild 2 von 2
    • Slide the wide plastic opening tool across the seem, separating it if you can't pry the device open using just the spudger.
    • Gently separate the case so none of the cords inside are disconnected
  3. Munchkinz LCD Assembly, Separated Device: Schritt 3, Bild 1 von 1
    • After prying the device apart, it should look like this.
  4. Munchkinz LCD Assembly, Remove Speaker: Schritt 4, Bild 1 von 1
    • Use the plastic opening tool to remove the speaker from the casing.
  5. Munchkinz LCD Assembly, Pry Camera: Schritt 5, Bild 1 von 1
    • Use the slim plastic opening tool to pry the camera from its position.
  6. Munchkinz LCD Assembly, Unscrew Volume Module: Schritt 6, Bild 1 von 2 Munchkinz LCD Assembly, Unscrew Volume Module: Schritt 6, Bild 2 von 2
    • Unscrew the two screws that hold the volume module to the casing.
  7. Munchkinz LCD Assembly, Pry Battery: Schritt 7, Bild 1 von 1
    • Use the plastic opening tool to slowly pry each side of the battery up.
    • Be careful not to bend the battery too much.
  8. Munchkinz LCD Assembly, Remove Ribbons: Schritt 8, Bild 1 von 1
    • Remove the two highlighted ribbons from the motherboard.
  9. Munchkinz LCD Assembly, Remove Screws: Schritt 9, Bild 1 von 1
    • Use the screw driver to remove the highlighted screws.
  10. Munchkinz LCD Assembly, Remove Hidden Screw: Schritt 10, Bild 1 von 1
    • Use the plastic opening tool to hold the camera ribbon back.
    • Unscrew the screw under ribbon with the screw driver.
  11. Munchkinz LCD Assembly, Remove Motherboard: Schritt 11, Bild 1 von 1
    • Remove the motherboard from the casing.
  12. Munchkinz LCD Assembly, Pry Up Screen: Schritt 12, Bild 1 von 3 Munchkinz LCD Assembly, Pry Up Screen: Schritt 12, Bild 2 von 3 Munchkinz LCD Assembly, Pry Up Screen: Schritt 12, Bild 3 von 3
    • Oriented the device so the battery is closest to the user.
    • Use the plastic opening tool to pry the clips up to release LCD screen.
    • Gently lift the northern end of the screen and slide it out horizontally.
  13. Munchkinz LCD Assembly, Solder LCD Wires: Schritt 13, Bild 1 von 1
    • Unsolder the black and red LCD wires.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
David Wood
440 Reputation
4 Anleitungen geschrieben
UW Tacoma, Team 3-6, Rose Winter 2015 Mitglied von UW Tacoma, Team 3-6, Rose Winter 2015
UWT-ROSE-W15S3G6
3 Mitglieder
14 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 380
