Einleitung
If your speaker in not functioning correctly, follow this guide and replace the speaker.
Was du brauchst
Slide the wide plastic opening tool across the seem, separating it if you can't pry the device open using just the spudger.
Use the slim plastic opening tool to remove the speaker from its position on the case.
Locate the red and black wires that connect the speaker to the motherboard.
Un-solder the red and black speaker wires that are connected to the motherboard
Fast fertig!
Abschluss
