Zum Hauptinhalt wechseln
Munchkinz Speaker Replacement
Was du brauchst
  1. Munchkinz Speaker Replacement, Opening Device: Schritt 1, Bild 1 von 1
    • Insert spudger into the USB Micro slot and pry the case apart.
    • Be careful not to go too deep and bend the prong inside the Micro USB port.
  2. Munchkinz Speaker Replacement, Pry Device Apart: Schritt 2, Bild 1 von 2 Munchkinz Speaker Replacement, Pry Device Apart: Schritt 2, Bild 2 von 2
    • Slide the wide plastic opening tool across the seem, separating it if you can't pry the device open using just the spudger.
    • Gently separate the case so none of the cords inside are disconnected
  3. Munchkinz Speaker Replacement, Separated Device: Schritt 3, Bild 1 von 1
    • After prying the device apart, it should look like this.
  4. Munchkinz Speaker Replacement, Pry Speaker: Schritt 4, Bild 1 von 2 Munchkinz Speaker Replacement, Pry Speaker: Schritt 4, Bild 2 von 2
    • Use the slim plastic opening tool to remove the speaker from its position on the case.
  5. Munchkinz Speaker Replacement, Locate Wires: Schritt 5, Bild 1 von 1
    • Locate the red and black wires that connect the speaker to the motherboard.
  6. Munchkinz Speaker Replacement, Solder Wires: Schritt 6, Bild 1 von 1
    • Un-solder the red and black speaker wires that are connected to the motherboard
Abschluss
David Wood
440 Reputation
4 Anleitungen geschrieben
UW Tacoma, Team 3-6, Rose Winter 2015 Mitglied von UW Tacoma, Team 3-6, Rose Winter 2015
UWT-ROSE-W15S3G6
3 Mitglieder
14 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 173
