Zum Hauptinhalt wechseln
Munchkinz Volume Button assembly
Was du brauchst
  1. Munchkinz Volume Button assembly, Opening Device: Schritt 1, Bild 1 von 1
    • Insert spudger into the USB Micro slot and pry the case apart.
    • Be careful not to go too deep and bend the prong inside the Micro USB port.
  2. Munchkinz Volume Button assembly, Pry Device Apart: Schritt 2, Bild 1 von 2 Munchkinz Volume Button assembly, Pry Device Apart: Schritt 2, Bild 2 von 2
    • Slide the wide plastic opening tool across the seem, separating it if you can't pry the device open using just the spudger.
    • Gently separate the case so none of the cords inside are disconnected
  3. Munchkinz Volume Button assembly, Separated Device: Schritt 3, Bild 1 von 1
    • After prying the device apart, it should look like this.
  4. Munchkinz Volume Button assembly, Pry Camera: Schritt 4, Bild 1 von 1
    • Use the slim plastic opening tool to pry the camera from its initial position.
  5. Munchkinz Volume Button assembly, Disconnect Ribbon: Schritt 5, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    • Use the precision tweezers to gently disconnect the camera ribbon that is connected to the motherboard.
  6. Munchkinz Volume Button assembly, Volume Button: Schritt 6, Bild 1 von 1
    • Remove the plastic volume button.
  7. Munchkinz Volume Button assembly, Unscrew Module: Schritt 7, Bild 1 von 1
    • Remove the two screws that hold the volume button assembly in place.
  8. Munchkinz Volume Button assembly, Solder Module Wires: Schritt 8, Bild 1 von 1
    • Un-solder the yellow, red, and black wires that connect the volume module to the motherboard.
Abschluss
David Wood
440 Reputation
4 Anleitungen geschrieben
UW Tacoma, Team 3-6, Rose Winter 2015 Mitglied von UW Tacoma, Team 3-6, Rose Winter 2015
UWT-ROSE-W15S3G6
3 Mitglieder
14 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 292
