Zum Hauptinhalt wechseln
MusicAngel JH-MD04E2 wired speakers Disassembly
Was du brauchst
  1. MusicAngel JH-MD04E2 wired speakers Disassembly, First assessment: Schritt 1, Bild 1 von 3 MusicAngel JH-MD04E2 wired speakers Disassembly, First assessment: Schritt 1, Bild 2 von 3 MusicAngel JH-MD04E2 wired speakers Disassembly, First assessment: Schritt 1, Bild 3 von 3
    • Bottom side has 4 5.95mm tapping Phillips #1 screws, under a rubber cover.
    • Under the label, there are two more Phillips #1 screws 9.15mm tapping screws.
  2. MusicAngel JH-MD04E2 wired speakers Disassembly, Opening the speaker: Schritt 2, Bild 1 von 3 MusicAngel JH-MD04E2 wired speakers Disassembly, Opening the speaker: Schritt 2, Bild 2 von 3 MusicAngel JH-MD04E2 wired speakers Disassembly, Opening the speaker: Schritt 2, Bild 3 von 3
    • Use a very thin metal prying tool and slide it in between the metal looking grill and the speaker body. Carefully pry it out (no glue is used) all the way around.
    • Repeat on both speaker sides.
  3. MusicAngel JH-MD04E2 wired speakers Disassembly, Taking out the parts: Schritt 3, Bild 1 von 3 MusicAngel JH-MD04E2 wired speakers Disassembly, Taking out the parts: Schritt 3, Bild 2 von 3 MusicAngel JH-MD04E2 wired speakers Disassembly, Taking out the parts: Schritt 3, Bild 3 von 3
    • Use a spudger to pry the battery that is glued to the top, from the body. Note: This is pretty strong adhesive.
    • Tilt the speaker grill / element a little, to slide it through the body.
  4. MusicAngel JH-MD04E2 wired speakers Disassembly, Information: Schritt 4, Bild 1 von 3 MusicAngel JH-MD04E2 wired speakers Disassembly, Information: Schritt 4, Bild 2 von 3 MusicAngel JH-MD04E2 wired speakers Disassembly, Information: Schritt 4, Bild 3 von 3
    • As you can see, there are no connectors used. All connections are soldered directly to the board.
    • No information can be found on the battery, either side.
    • The speaker elements are 45mm, 3W and 4Ω
  5. MusicAngel JH-MD04E2 wired speakers Disassembly, Board overview: Schritt 5, Bild 1 von 1
    • Not really much going on on this board.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Master Techs Mitglied von Master Techs
Community
312 Mitglieder
1.330 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 1
Letzten 7 Tage: 2
Letzten 30 Tage: 7
Insgesamt: 87
