Was du brauchst
Myco MM-600, with cover on
To complete this guide you will need a small Phillips-head screwdriver and a can of compressed air.
Turn the Myco over and remove the battery cover and the batteries. Remove the 2 screws indicated in the red oval (leave the remaining 2 screws on the left as they are)
Once you have removed the 2 screws in Step 2, turn the scale over and you will find that the weigh plate has fallen off (the plate is to the left in the picture).
Now we can access the interior of the scale by removing the four screws indicated by the red circles
Now you will be able to split the scale open along the indicated line. It should come open easily just using your fingers, there are no plastic tabs or anything.
Be careful while opening, there are a bunch of small cables that can be easily broken.
There is a circuit board mounted (with screws) that covers the actual buttons. I have not removed this board, but taken a can of compressed air and sprayed into the cracks around the edge of the board to try to clean any dust or other substance that may be affecting the operation of the ON/OFF key.
It is evident from the picture that crud does get inside the scale (blow this out too, while you are there!
This is all I have needed to do (this is the second time I have had to do this in the 7 years I have had this scale).
To reassemble the scale, follow these steps in reverse. When replacing the weighing plate, you can look in from the side to catch the screw positions on the weigh plate.
