Zum Hauptinhalt wechseln
N-Strike Nite Finder EX-3 Battery Replacement
Was du brauchst
  1. N-Strike Nite Finder EX-3 Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • The batteries are located in the handle of the blaster.
    • The base plate is held in place with a single phillips head, 8.2 mm screw. Remove this screw and remove the base plate to access the battery compartment.
  2. N-Strike Nite Finder EX-3 Battery Replacement: Schritt 2, Bild 1 von 1
    • Once the batteries have been removed, you can check to see if they have any charge left in them with a battery tester.
    • If they are in fact dead, replace them with standard AA type batteries in the correct orientation.
Abschluss
Michigan Tech, Team 5-8, Lauer Spring 2014 Mitglied von Michigan Tech, Team 5-8, Lauer Spring 2014
MTU-LAUER-S14S5G8
3 Mitglieder
13 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 15
Insgesamt: 2,620
