Zum Hauptinhalt wechseln
NABI XD Battery Replacement
Was du brauchst
  1. NABI XD Battery Replacement, Rear panel: Schritt 1, Bild 1 von 2 NABI XD Battery Replacement, Rear panel: Schritt 1, Bild 2 von 2
    • Use the plastic opening tool at the top left corner seam, then pry the corner apart.
  2. NABI XD Battery Replacement: Schritt 2, Bild 1 von 1
    • Next slide the plastic opening tool across the sides of the Nabi. It will slowly open.
    • There are small plastic clips that need to be release. Gently apply outwards pressure until the clips give.
    • Go around the NABI XD and separate the rear panel from the device.
  3. NABI XD Battery Replacement, Battery: Schritt 3, Bild 1 von 2 NABI XD Battery Replacement, Battery: Schritt 3, Bild 2 von 2
    • Place your fingernails on both sides of the connector and pull it straight back away from the holder.
  4. NABI XD Battery Replacement: Schritt 4, Bild 1 von 1
    • Battery is glued to the base, lift carefully.
    • To remove battery, lift the battery up from the motherboard.
Abschluss
USF Tampa, Team 17-2, Blackwell Fall 2016 Mitglied von USF Tampa, Team 17-2, Blackwell Fall 2016
USFT-BLACKWELL-F16S17G2
3 Mitglieder
12 Anleitungen geschrieben
Ein Kommentar
Where can you get the battery?
Dave - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 782
