Zum Hauptinhalt wechseln
Fix Your Stuff
Right to Repair
Parts & Tools
Einleitung
Has the battery been damaged or the device won't charge. Changing the battery may fix these problems.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Use the plastic opening tool at the top left corner seam, then pry the corner apart. Use the plastic opening tool at the top left corner seam, then pry the corner apart.
    • Use the plastic opening tool at the top left corner seam, then pry the corner apart.
  2. Next slide the plastic opening tool across the sides of the Nabi. It will slowly open.
    • Next slide the plastic opening tool across the sides of the Nabi. It will slowly open.
    • There are small plastic clips that need to be release. Gently apply outwards pressure until the clips give.
    • Go around the NABI XD and separate the rear panel from the device.
  3. Place your fingernails on both sides of the connector and pull it straight back away from the holder. Place your fingernails on both sides of the connector and pull it straight back away from the holder.
    • Place your fingernails on both sides of the connector and pull it straight back away from the holder.
  4. Battery is glued to the base, lift carefully.
    • Battery is glued to the base, lift carefully.
    • To remove battery, lift the battery up from the motherboard.
Abschluss
Marissa Schiereck
638 Reputation
6 Anleitungen geschrieben
USF Tampa, Team 17-2, Blackwell Fall 2016 Mitglied von USF Tampa, Team 17-2, Blackwell Fall 2016
USFT-BLACKWELL-F16S17G2
3 Mitglieder
12 Anleitungen geschrieben
Where can you get the battery?
Dave - Antwort
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 6
Insgesamt: 528
