Einleitung
Is your charging port damaged, can't charge your device no matter what you have tried. Replacing the charging port may fix those problems.
Was du brauchst
Use the plastic opening tool at the top left corner seam, then pry the corner apart.
Next slide the plastic opening tool across the sides of the Nabi. It will slowly open.
There are small plastic clips that need to be release. Gently apply outwards pressure until the clips give.
Go around the NABI XD and separate the rear panel from the device.
Place your fingernails on both sides of the connector and pull it straight back away from the holder.
Remove the two 4mm Phillips screws with the PH#0 screwdriver.
Disconnect the left (L) speaker wire from the charging port by grabbing it on both sides with the tweezers and pulling straight back.
Use your fingernails or a spudger to flip up the small retaining flap, then pull the ribbon straight back to remove
Lift the charging port from the NABI XD.
