Zum Hauptinhalt wechseln
NABI XD Charging port Replacement
Was du brauchst
  1. NABI XD Charging port Replacement, Rear panel: Schritt 1, Bild 1 von 2 NABI XD Charging port Replacement, Rear panel: Schritt 1, Bild 2 von 2
    • Use the plastic opening tool at the top left corner seam, then pry the corner apart.
  2. NABI XD Charging port Replacement: Schritt 2, Bild 1 von 1
    • Next slide the plastic opening tool across the sides of the Nabi. It will slowly open.
    • There are small plastic clips that need to be release. Gently apply outwards pressure until the clips give.
    • Go around the NABI XD and separate the rear panel from the device.
  3. NABI XD Charging port Replacement, Battery: Schritt 3, Bild 1 von 2 NABI XD Charging port Replacement, Battery: Schritt 3, Bild 2 von 2
    • Place your fingernails on both sides of the connector and pull it straight back away from the holder.
  4. NABI XD Charging port Replacement: Schritt 4, Bild 1 von 1
    • Battery is glued to the base, lift carefully.
    • To remove battery, lift the battery up from the motherboard.
  5. NABI XD Charging port Replacement, Charging port: Schritt 5, Bild 1 von 2 NABI XD Charging port Replacement, Charging port: Schritt 5, Bild 2 von 2
    • Remove the two 4mm Phillips screws with the PH#0 screwdriver.
    • Disconnect the left (L) speaker wire from the charging port by grabbing it on both sides with the tweezers and pulling straight back.
  6. NABI XD Charging port Replacement: Schritt 6, Bild 1 von 1
    • Use your fingernails or a spudger to flip up the small retaining flap, then pull the ribbon straight back to remove
    • Lift the charging port from the NABI XD.
Abschluss
USF Tampa, Team 17-2, Blackwell Fall 2016 Mitglied von USF Tampa, Team 17-2, Blackwell Fall 2016
USFT-BLACKWELL-F16S17G2
3 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 554
