Einleitung
This is the first step when replacing any component in the NABI XD. This guide should be used when fixing any part of your device.
Was du brauchst
Use the plastic opening tool at the top left corner seam, then pry the corner apart.
Next slide the plastic opening tool across the sides of the Nabi. It will slowly open.
There are small plastic clips that need to be release. Gently apply outwards pressure until the clips give.
Go around the NABI XD and separate the rear panel from the device.
