Zum Hauptinhalt wechseln
NABI XD Screen Replacement
Was du brauchst
  1. NABI XD Screen Replacement, Rear panel: Schritt 1, Bild 1 von 2 NABI XD Screen Replacement, Rear panel: Schritt 1, Bild 2 von 2
    • Use the plastic opening tool at the top left corner seam, then pry the corner apart.
  2. NABI XD Screen Replacement: Schritt 2, Bild 1 von 1
    • Next slide the plastic opening tool across the sides of the Nabi. It will slowly open.
    • There are small plastic clips that need to be release. Gently apply outwards pressure until the clips give.
    • Go around the NABI XD and separate the rear panel from the device.
  3. NABI XD Screen Replacement, Battery: Schritt 3, Bild 1 von 2 NABI XD Screen Replacement, Battery: Schritt 3, Bild 2 von 2
    • Place your fingernails on both sides of the connector and pull it straight back away from the holder.
  4. NABI XD Screen Replacement: Schritt 4, Bild 1 von 1
    • Battery is glued to the base, lift carefully.
    • To remove battery, lift the battery up from the motherboard.
  5. NABI XD Screen Replacement, Charging port: Schritt 5, Bild 1 von 2 NABI XD Screen Replacement, Charging port: Schritt 5, Bild 2 von 2
    • Remove the two 4mm Phillips screws with the PH#0 screwdriver.
    • Disconnect the left (L) speaker wire from the charging port by grabbing it on both sides with the tweezers and pulling straight back.
  6. NABI XD Screen Replacement: Schritt 6, Bild 1 von 1
    • Use your fingernails or a spudger to flip up the small retaining flap, then pull the ribbon straight back to remove
    • Lift the charging port from the NABI XD.
  7. NABI XD Screen Replacement, Motherboard: Schritt 7, Bild 1 von 3 NABI XD Screen Replacement, Motherboard: Schritt 7, Bild 2 von 3 NABI XD Screen Replacement, Motherboard: Schritt 7, Bild 3 von 3
    • To remove the marked ribbons, use your fingernails or a spudger to lift up small tab
    • Use the Precision Tweezers to gently pull the ribbons straight out of the connectors.
    • You need to remove 4 ribbons
  8. NABI XD Screen Replacement: Schritt 8, Bild 1 von 3 NABI XD Screen Replacement: Schritt 8, Bild 2 von 3 NABI XD Screen Replacement: Schritt 8, Bild 3 von 3
    • Disconnect the camera by lifting the ribbon straight up. Also disconnect the remaining ribbon by lifting up gently.
    • To disconnect antenna wire, use the tweezers to pry connector straight from the board.
  9. NABI XD Screen Replacement: Schritt 9, Bild 1 von 2 NABI XD Screen Replacement: Schritt 9, Bild 2 von 2
    • Disconnect the Right speaker by grabbing the wire head by its sides and pulling it back from the connector.
  10. NABI XD Screen Replacement: Schritt 10, Bild 1 von 2 NABI XD Screen Replacement: Schritt 10, Bild 2 von 2
    • Remove the four 4mm Phillips screws with the PH#0 screwdriver.
  11. NABI XD Screen Replacement: Schritt 11, Bild 1 von 1
    • Lift the motherboard up away from the Nabi XD.
  12. NABI XD Screen Replacement, Speakers: Schritt 12, Bild 1 von 3 NABI XD Screen Replacement, Speakers: Schritt 12, Bild 2 von 3 NABI XD Screen Replacement, Speakers: Schritt 12, Bild 3 von 3
    • Right (R) speaker removal:
    • Remove one 4mm Phillips screw.
    • Use the metal spudger to separate the speaker from the frame.
    • The speaker is glued to the Nabi XD it will require some force to separate them.
  13. NABI XD Screen Replacement: Schritt 13, Bild 1 von 2 NABI XD Screen Replacement: Schritt 13, Bild 2 von 2
    • Remove the left (L) speaker wire from the frame by pulling it to the side and up.
    • The wire in this step, is connected to the charging port. Removing it, is shown in detail on step 6.
  14. NABI XD Screen Replacement: Schritt 14, Bild 1 von 3 NABI XD Screen Replacement: Schritt 14, Bild 2 von 3 NABI XD Screen Replacement: Schritt 14, Bild 3 von 3
    • Left (L) speaker removal:
    • Remove two 4mm Phillips screws.
  15. NABI XD Screen Replacement, Screen: Schritt 15, Bild 1 von 3 NABI XD Screen Replacement, Screen: Schritt 15, Bild 2 von 3 NABI XD Screen Replacement, Screen: Schritt 15, Bild 3 von 3
    • The ribbons are glued to the frame so gently lift them up without ripping them.
    • Lightly lift the marked wires and ribbons from the frame by gently pulling them in the direction of the arrows and up.
    • Remove five 4mm Phillips screws from the frame.
  16. NABI XD Screen Replacement: Schritt 16, Bild 1 von 2 NABI XD Screen Replacement: Schritt 16, Bild 2 von 2
    • Use the Plastic Opening tools to lift the frame up.
    • The ribbons need to be detangled from the frame while you are lifting it up.
    • Do not yank the frame away from the Nabi XD it is connect to it by a ribbon. Gently lift.
  17. NABI XD Screen Replacement: Schritt 17, Bild 1 von 2 NABI XD Screen Replacement: Schritt 17, Bild 2 von 2
    • Lift the screen up with the black spudger.
    • Lift the frame up slowly and place it to the side.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
USF Tampa, Team 17-2, Blackwell Fall 2016 Mitglied von USF Tampa, Team 17-2, Blackwell Fall 2016
USFT-BLACKWELL-F16S17G2
3 Mitglieder
12 Anleitungen geschrieben
Ein Kommentar
Will the screen from an A or C model work with a B model?
Kevin Fifer - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 6
Insgesamt: 659
