Einleitung
Is the screen cracked or non responsive then replacing it will fix the NABI XD.
Was du brauchst
Use the plastic opening tool at the top left corner seam, then pry the corner apart.
Next slide the plastic opening tool across the sides of the Nabi. It will slowly open.
There are small plastic clips that need to be release. Gently apply outwards pressure until the clips give.
Go around the NABI XD and separate the rear panel from the device.
Place your fingernails on both sides of the connector and pull it straight back away from the holder.
Use your fingernails or a spudger to flip up the small retaining flap, then pull the ribbon straight back to remove
Lift the charging port from the NABI XD.
Disconnect the camera by lifting the ribbon straight up. Also disconnect the remaining ribbon by lifting up gently.
To disconnect antenna wire, use the tweezers to pry connector straight from the board.
Disconnect the Right speaker by grabbing the wire head by its sides and pulling it back from the connector.
Right (R) speaker removal:
Remove one 4mm Phillips screw.
Use the metal spudger to separate the speaker from the frame.
Remove the left (L) speaker wire from the frame by pulling it to the side and up.
Left (L) speaker removal:
Remove two 4mm Phillips screws.
The ribbons are glued to the frame so gently lift them up without ripping them.
Lightly lift the marked wires and ribbons from the frame by gently pulling them in the direction of the arrows and up.
Remove five 4mm Phillips screws from the frame.
Use the Plastic Opening tools to lift the frame up.
The ribbons need to be detangled from the frame while you are lifting it up.
Lift the screen up with the black spudger.
Lift the frame up slowly and place it to the side.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
