Zum Hauptinhalt wechseln
NEC LCD1770NX Fuse Replacement
Was du brauchst
  1. NEC LCD1770NX Fuse Replacement, Stand: Schritt 1, Bild 1 von 2 NEC LCD1770NX Fuse Replacement, Stand: Schritt 1, Bild 2 von 2
    • Place the monitor face down on a clean, flat surface.
  2. NEC LCD1770NX Fuse Replacement: Schritt 2, Bild 1 von 2 NEC LCD1770NX Fuse Replacement: Schritt 2, Bild 2 von 2
    • Firmly remove the back panel of the stand by pulling it up and away from the monitor.
  3. NEC LCD1770NX Fuse Replacement: Schritt 3, Bild 1 von 2 NEC LCD1770NX Fuse Replacement: Schritt 3, Bild 2 von 2
    • Unscrew the two 6mm Phillips PH2 screws to detach the stand enclosure from the stand.
  4. NEC LCD1770NX Fuse Replacement: Schritt 4, Bild 1 von 2 NEC LCD1770NX Fuse Replacement: Schritt 4, Bild 2 von 2
    • Firmly grasp the stand enclosure with your hand and slide it to base of stand.
  5. NEC LCD1770NX Fuse Replacement: Schritt 5, Bild 1 von 1
    • Unscrew the two 14.5mm Phillips PH2 screws holding the stand to the monitor.
  6. NEC LCD1770NX Fuse Replacement: Schritt 6, Bild 1 von 2 NEC LCD1770NX Fuse Replacement: Schritt 6, Bild 2 von 2
    • Lift the the stand straight up to remove it.
  7. NEC LCD1770NX Fuse Replacement, Monitor Enclosure: Schritt 7, Bild 1 von 3 NEC LCD1770NX Fuse Replacement, Monitor Enclosure: Schritt 7, Bild 2 von 3 NEC LCD1770NX Fuse Replacement, Monitor Enclosure: Schritt 7, Bild 3 von 3
    • Place the monitor screen face up.
    • Pull the frame off by placing your fingers on the inside of the frame and pulling out and up, the frame should snap off.
    • Continue your way around the screen.
  8. NEC LCD1770NX Fuse Replacement: Schritt 8, Bild 1 von 3 NEC LCD1770NX Fuse Replacement: Schritt 8, Bild 2 von 3 NEC LCD1770NX Fuse Replacement: Schritt 8, Bild 3 von 3
    • Unscrew the two 7mm screws from the bottom of the button assembly.
    • Do not pull the button assembly out too quickly or with too much force! Damage to the wires can occur.
    • Pull the button assembly out a few inches and unplug the colored cables.
  9. NEC LCD1770NX Fuse Replacement: Schritt 9, Bild 1 von 2 NEC LCD1770NX Fuse Replacement: Schritt 9, Bild 2 von 2
    • Unscrew the gold colored 7mm Phillips PH000 screw holding the button assembly to the monitor.
    • Remove the button assembly from the monitor.
  10. NEC LCD1770NX Fuse Replacement: Schritt 10, Bild 1 von 1
    • With the monitor face-down, unscrew the 5 7mm Phillips PH2 screws around the outside of the enclosure.
  11. NEC LCD1770NX Fuse Replacement: Schritt 11, Bild 1 von 3 NEC LCD1770NX Fuse Replacement: Schritt 11, Bild 2 von 3 NEC LCD1770NX Fuse Replacement: Schritt 11, Bild 3 von 3
    • Unscrew the 2 14.5mm Phillips PH2 screws located on the raised center of the enclosure.
    • Carefully pull the enclosure off the monitor.
  12. NEC LCD1770NX Fuse Replacement: Schritt 12, Bild 1 von 2 NEC LCD1770NX Fuse Replacement: Schritt 12, Bild 2 von 2
    • Unscrew the 10 5mm Philips PH2 screws holding the metal casing to the monitor.
  13. NEC LCD1770NX Fuse Replacement: Schritt 13, Bild 1 von 2 NEC LCD1770NX Fuse Replacement: Schritt 13, Bild 2 von 2
    • Pull the the metal casing off of the monitor to reveal the motherboards.
  14. NEC LCD1770NX Fuse Replacement, Fuse: Schritt 14, Bild 1 von 2 NEC LCD1770NX Fuse Replacement, Fuse: Schritt 14, Bild 2 von 2
    • Carefully insert the prying tool underneath the power supply fuse.
    • Using the prying tool, lift the power supply fuse out of its emplacement until it is resting on its clamps.
  15. NEC LCD1770NX Fuse Replacement: Schritt 15, Bild 1 von 1
    • Carefully remove the power supply fuse by hand.
  16. NEC LCD1770NX Fuse Replacement: Schritt 16, Bild 1 von 3 NEC LCD1770NX Fuse Replacement: Schritt 16, Bild 2 von 3 NEC LCD1770NX Fuse Replacement: Schritt 16, Bild 3 von 3
    • Place the replacement power supply fuse on the fuse clips.
    • With a finger, press down on the ends of the replacement fuse until it is properly seated in the fuse clips.
Abschluss
Cal Poly, Team 11-36, Amido Fall 2013 Mitglied von Cal Poly, Team 11-36, Amido Fall 2013
CPSU-AMIDO-F13S11G36
5 Mitglieder
7 Anleitungen geschrieben
Ein Kommentar
Thanks for sharing the step by step procedure. It will be helpful to provide the model/type of the replacement fuse so that we can order it in advance and have it ready to replace the bad one while the monitor is open.
Ja Hui - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 5
Insgesamt: 923
