Zum Hauptinhalt wechseln
NEC LCD1770NX Screen Replacement
Was du brauchst
  1. NEC LCD1770NX Screen Replacement, Stand: Schritt 1, Bild 1 von 2 NEC LCD1770NX Screen Replacement, Stand: Schritt 1, Bild 2 von 2
    • Place the monitor face down on a clean, flat surface.
  2. NEC LCD1770NX Screen Replacement: Schritt 2, Bild 1 von 2 NEC LCD1770NX Screen Replacement: Schritt 2, Bild 2 von 2
    • Firmly remove the back panel of the stand by pulling it up and away from the monitor.
  3. NEC LCD1770NX Screen Replacement: Schritt 3, Bild 1 von 2 NEC LCD1770NX Screen Replacement: Schritt 3, Bild 2 von 2
    • Unscrew the two 6mm Phillips PH2 screws to detach the stand enclosure from the stand.
  4. NEC LCD1770NX Screen Replacement: Schritt 4, Bild 1 von 2 NEC LCD1770NX Screen Replacement: Schritt 4, Bild 2 von 2
    • Firmly grasp the stand enclosure with your hand and slide it to base of stand.
  5. NEC LCD1770NX Screen Replacement: Schritt 5, Bild 1 von 1
    • Unscrew the two 14.5mm Phillips PH2 screws holding the stand to the monitor.
  6. NEC LCD1770NX Screen Replacement: Schritt 6, Bild 1 von 2 NEC LCD1770NX Screen Replacement: Schritt 6, Bild 2 von 2
    • Lift the the stand straight up to remove it.
  7. NEC LCD1770NX Screen Replacement, Monitor Enclosure: Schritt 7, Bild 1 von 3 NEC LCD1770NX Screen Replacement, Monitor Enclosure: Schritt 7, Bild 2 von 3 NEC LCD1770NX Screen Replacement, Monitor Enclosure: Schritt 7, Bild 3 von 3
    • Place the monitor screen face up.
    • Pull the frame off by placing your fingers on the inside of the frame and pulling out and up, the frame should snap off.
    • Continue your way around the screen.
  8. NEC LCD1770NX Screen Replacement: Schritt 8, Bild 1 von 3 NEC LCD1770NX Screen Replacement: Schritt 8, Bild 2 von 3 NEC LCD1770NX Screen Replacement: Schritt 8, Bild 3 von 3
    • Unscrew the two 7mm screws from the bottom of the button assembly.
    • Do not pull the button assembly out too quickly or with too much force! Damage to the wires can occur.
    • Pull the button assembly out a few inches and unplug the colored cables.
  9. NEC LCD1770NX Screen Replacement: Schritt 9, Bild 1 von 2 NEC LCD1770NX Screen Replacement: Schritt 9, Bild 2 von 2
    • Unscrew the gold colored 7mm Phillips PH000 screw holding the button assembly to the monitor.
    • Remove the button assembly from the monitor.
  10. NEC LCD1770NX Screen Replacement: Schritt 10, Bild 1 von 1
    • With the monitor face-down, unscrew the 5 7mm Phillips PH2 screws around the outside of the enclosure.
  11. NEC LCD1770NX Screen Replacement: Schritt 11, Bild 1 von 3 NEC LCD1770NX Screen Replacement: Schritt 11, Bild 2 von 3 NEC LCD1770NX Screen Replacement: Schritt 11, Bild 3 von 3
    • Unscrew the 2 14.5mm Phillips PH2 screws located on the raised center of the enclosure.
    • Carefully pull the enclosure off the monitor.
  12. NEC LCD1770NX Screen Replacement: Schritt 12, Bild 1 von 2 NEC LCD1770NX Screen Replacement: Schritt 12, Bild 2 von 2
    • Unscrew the 10 5mm Philips PH2 screws holding the metal casing to the monitor.
  13. NEC LCD1770NX Screen Replacement: Schritt 13, Bild 1 von 2 NEC LCD1770NX Screen Replacement: Schritt 13, Bild 2 von 2
    • Pull the the metal casing off of the monitor to reveal the motherboards.
  14. NEC LCD1770NX Screen Replacement, Screen: Schritt 14, Bild 1 von 2 NEC LCD1770NX Screen Replacement, Screen: Schritt 14, Bild 2 von 2
    • Unplug the pink and light blue attachments from the side of the brown board by pulling up on the tabs and gently pulling the cord out.
    • Label where the plugs go.
  15. NEC LCD1770NX Screen Replacement: Schritt 15, Bild 1 von 2 NEC LCD1770NX Screen Replacement: Schritt 15, Bild 2 von 2
    • Unplug the 3 multicolored cables from the blue board by gently wiggling them back and forth while pulling up.
  16. NEC LCD1770NX Screen Replacement: Schritt 16, Bild 1 von 2 NEC LCD1770NX Screen Replacement: Schritt 16, Bild 2 von 2
    • Unscrew the 4 5mm Phillips PH2 screws on the sides of the monitor.
  17. NEC LCD1770NX Screen Replacement: Schritt 17, Bild 1 von 3 NEC LCD1770NX Screen Replacement: Schritt 17, Bild 2 von 3 NEC LCD1770NX Screen Replacement: Schritt 17, Bild 3 von 3
    • Begin opening the enclosure by slowing pulling up on back panel of the monitor.
    • The enclosure should still be attached by a cable; this cable is held down by tape. Remove this tape.
  18. NEC LCD1770NX Screen Replacement: Schritt 18, Bild 1 von 3 NEC LCD1770NX Screen Replacement: Schritt 18, Bild 2 von 3 NEC LCD1770NX Screen Replacement: Schritt 18, Bild 3 von 3
    • Unplug the cable from the screen. It is still attached by a fragile black belt.
    • Use a spudger to break the black ceramic belt to free the screen from the rest, allowing it to be replaced.
Abschluss
John Patterson
253 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 11-36, Amido Fall 2013 Mitglied von Cal Poly, Team 11-36, Amido Fall 2013
CPSU-AMIDO-F13S11G36
5 Mitglieder
7 Anleitungen geschrieben
Ein Kommentar
Thank you very much for this tutorial. The steps are very specific and detailed. I bought a new NEC LCD1770NX LCD Display Screen online and installed it according to the steps in the article. Finally, the machine worked normally again. Thank you very much.
sean - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 14
Insgesamt: 1,883
