Einleitung
Replacing the NERF Doomlands 2169 Lawbringer Blaster spring is a moderately simple task taking fifteen to thirty minutes to complete. There are no special skills required for this repair. The main spring is responsible for pushing the plunger forward when firing and storing the plunger in a backward position when the gun is primed. The main spring may need to be replaced if the user finds the toy is losing its performance.
Was du brauchst
Remove sixteen screws from the outer case.
Remove the outer case from the rest of the device.
Remove the exterior spring from the sliding mechanism and rotate the gun to the opposite side.
Remove the three screws holding the trigger plate in place, then remove the plate carefully.
Carefully slide out the big spring and fit in your replacement (the thin-coil end is coiled around the orange plastic).
Keep tension on the spring and begin sliding the new coil spring into the trigger mechanism.
Reconnect the spring to the orange slider and connect the orange slider to the grey hook.
Carefully reassemble the NERF Lawbringer in the same order you took it apart. Carefully reattach the three screws that seal the air chamber.
Reattach the other plastic half of the gun. Tighten the screws and you're done.
