Zum Hauptinhalt wechseln
Einleitung
Removing the lower case allows you to replace the hardware inside the device.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Turn the device so that the bottom is facing up.
    • Turn the device so that the bottom is facing up.
  2. Use the plastic opening tool to carefully lift the rubber stops in each corner. Do not completely remove the rubber stops, because they are difficult to replace. Do not completely remove the rubber stops, because they are difficult to replace.
    • Use the plastic opening tool to carefully lift the rubber stops in each corner.
    • Do not completely remove the rubber stops, because they are difficult to replace.
  3. Unscrew the 4 11.8 mm T-8 Torx screws from each corner of the device. Unscrew the 4 11.8 mm T-8 Torx screws from each corner of the device.
    • Unscrew the 4 11.8 mm T-8 Torx screws from each corner of the device.
  4. Lift the lower case straight up from the rest of the router. Lift the lower case straight up from the rest of the router.
    • Lift the lower case straight up from the rest of the router.
Abschluss
Nicole Slagle
83 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 3-31, Amido Winter 2013 Mitglied von Cal Poly, Team 3-31, Amido Winter 2013
CPSU-AMIDO-W13S3G31
3 Mitglieder
6 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 334
