Einleitung
Removing the motherboard will allow you to replace it, or give you access to the other components that are attached to it.
Was du brauchst
Use the plastic opening tool to carefully lift the rubber stops in each corner.
Remove the clear plastic casing by lifting it straight up from the router.
Separate the motherboard from the top shell by lifting it straight up from the router.
Eine weitere Person hat diese Anleitung absolviert.
