Zum Hauptinhalt wechseln
NETGEAR WPN824 v3 Top LED Controller Replacement
Was du brauchst
  1. NETGEAR WPN824 v3  Top LED Controller  Replacement, Remove Screw Covers: Schritt 1, Bild 1 von 1
    • Turn the device upside down. Remove the 4 rubber screw covers at each corner.
    • Pinch the screw covers and pull them up slowly. You may have to twist and turn them around to get them detached.
  2. NETGEAR WPN824 v3  Top LED Controller  Replacement, Remove Screws: Schritt 2, Bild 1 von 1
    • Remove the six 3mm T15 Torx screws. Four screws on the corner of the router and two in the middle
    • Use your T15 Torx Screwdriver on each screw and set them aside. These are the only screws you need to remove throughout the repair.
  3. NETGEAR WPN824 v3  Top LED Controller  Replacement, Remove Back Cover: Schritt 3, Bild 1 von 1
    • Once the screws have been removed you can remove the cover to reveal the motherboard.
    • You can use the ESD-safe pry tool on one of the small side openings to pry it open.
  4. NETGEAR WPN824 v3  Top LED Controller  Replacement, Detach Cable From LED Controller: Schritt 4, Bild 1 von 2 NETGEAR WPN824 v3  Top LED Controller  Replacement, Detach Cable From LED Controller: Schritt 4, Bild 2 von 2
    • Now that you have the case off you can slowly lift the motherboard from the top case piece.
    • Detach the cable connecting the LED controller to the motherboard. Place the motherboard aside. You will now have access to the LED Controller.
  5. NETGEAR WPN824 v3  Top LED Controller  Replacement, Detach LED Controller: Schritt 5, Bild 1 von 1
    • The LED Controller will be pinned down by some plastic clips. Use the ESD-safe pry tool to detach the LED controller.
    • WARNING: There are 4 clips and they are transparent. Detach all of them before removing the controller. Handle the clips and LED controller with care.
  6. NETGEAR WPN824 v3  Top LED Controller  Replacement, Final Step: Schritt 6, Bild 1 von 1
    • Now that you have detached the controller you can slowly lift it out of the plastic holds.
    • Congratulations! You have successfully removed the LED controller!
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Ein Kommentar
tl;dr
1. Take out led controller.
2. Examine what I have done.
funkybluemonkey3 - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 196
