Einleitung
This guide will show you how to replace the lens on the Nikon Coolpix A900.
You may need to replace the lens of the camera if it suffers a hard drop or water damage. A good indicator that you should replace the lens is if the lens has any kind of damage like a crack or scratches.
To help with this guide, make sure that you have a way to organize the components that you will be removing.
Was du brauchst
Orient the camera so that it is upside down, with the lens facing towards you.
Slide the battery door lock left to unlock it.
The battery door will automatically open.
Orient the camera upside down, with the lens facing away from you.
Remove the two 3mm Phillips #00 screws from the right.
Remove the two 3.4mm Phillips #00 screws from the left.
Turn the camera on its side, with the lens facing away from you.
Remove the 3.4mm Phillips #00 screw. Repeat this for the opposite side of the camera.
Place the camera upright with the lens facing away from you.
Move the monitor down, and remove two 4.4 mm screws.
Place the camera lens down, while supporting the rear case.
Unlock the two ribbons by using your finger to lift the plastic hinge on the ribbon connector.
With the ribbons disconnected, you can now remove the rear case.
Place the camera in front of you with the lens facing down.
On the top right, remove the 4.5 mm Phillips #00 screw holding the input shield.
Remove the 4.5 mm Phillips #00 screw holding the bracket in the bottom right.
Remove the 2.5 mm Phillips #00 rear brace screw.
Use your finger to undo the ribbon connector on the top right of the camera.
Remove the two 2.5mm Phillips #00 screws holding the small chip in place. Remove the small chip.
Remove the final two 4.5 mm Phillips #00 screws from the left side of the brace.
Carefully lift the lens out of the camera.
It may be necessary to gently pry these tabs out of the way to release the lens.
6 weitere Nutzer:innen haben diese Anleitung absolviert.
2 Kommentare
How to replace the front-lens of the zoom-lens, when it’s scratched!?!
