Zum Hauptinhalt wechseln
Einleitung
This guide is used to help remove the clear door off the popcorn maker. In order to begin to remove the door, be sure that the machine is unplugged from any outlets and the device is lying on its side.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Unplug the machine and tilt the machine on its side.
    • Unplug the machine and tilt the machine on its side.
  2. Using a Phillips #1 screwdriver, remove the four 12  mm screws  on the red door hinge as indicated, from both the front and side. Using a Phillips #1 screwdriver, remove the four 12  mm screws  on the red door hinge as indicated, from both the front and side.
    • Using a Phillips #1 screwdriver, remove the four 12 mm screws on the red door hinge as indicated, from both the front and side.
  3. Remove the red door hinge from the popcorn machine.
    • Remove the red door hinge from the popcorn machine.
Abschluss
Max O'Rourke
97 Reputation
1 Anleitung geschrieben
UC Davis, Team S4-G4, Lore Fall 2018 Mitglied von UC Davis, Team S4-G4, Lore Fall 2018
UCD-LORE-F18S4G4
3 Mitglieder
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 3
Insgesamt: 233
