Einleitung
Use this guide to replace a faulty or outdated GPU, in this case, an NVIDIA GeForce GTX 970 in a HAF 912 case.
The graphics card, or GPU, is a piece of hardware that allows a computer to display images and videos more effectively. A failing video card can lead to crashes and issues running certain software.
Was du brauchst
Unplug all the external cables from the computer and ensure that the power supply is switched off.
Remove the case side panel by applying pressure to the side and sliding the side panel toward the back of the case.
Remove the two Philips #1 mounting screws that attach the GPU to the inside of the case.
Remove the GPU from the case. If it does not move, check to make sure that steps 3-5 were properly performed.
Once the replacement GPU is lined up, press down until you hear a click or can see that the locking tab is flipped up again.
To finish reassembly, follow steps 2-4 in reverse order.
11 weitere Nutzer:innen haben diese Anleitung absolviert.
