Zum Hauptinhalt wechseln
NVIDIA SHIELD Portable Motherboard Replacement
Was du brauchst
  1. NVIDIA SHIELD Portable Motherboard Replacement, Remove Front Panel: Schritt 1, Bild 1 von 3 NVIDIA SHIELD Portable Motherboard Replacement, Remove Front Panel: Schritt 1, Bild 2 von 3 NVIDIA SHIELD Portable Motherboard Replacement, Remove Front Panel: Schritt 1, Bild 3 von 3
    • Remove the seven 6.4mm T5 Torx screws from the back panel.
    • Use the spudger to separate the front and back panels.
  2. NVIDIA SHIELD Portable Motherboard Replacement, Remove Green Grill: Schritt 2, Bild 1 von 2 NVIDIA SHIELD Portable Motherboard Replacement, Remove Green Grill: Schritt 2, Bild 2 von 2
    • The green grill is not screwed in so it can be pulled right out.
  3. NVIDIA SHIELD Portable Motherboard Replacement, Remove Battery Cables: Schritt 3, Bild 1 von 3 NVIDIA SHIELD Portable Motherboard Replacement, Remove Battery Cables: Schritt 3, Bild 2 von 3 NVIDIA SHIELD Portable Motherboard Replacement, Remove Battery Cables: Schritt 3, Bild 3 von 3
    • Remove the six 6.5mm T5 Torx screws.
    • Disconnect the power wires.
    • Peel back the copper tape and disconnect the black and white wires.
  4. NVIDIA SHIELD Portable Motherboard Replacement, Remove Battery Apparatus: Schritt 4, Bild 1 von 1
    • Pull the battery apparatus out once all cables are removed.
  5. NVIDIA SHIELD Portable Motherboard Replacement, Removing Fan: Schritt 5, Bild 1 von 3 NVIDIA SHIELD Portable Motherboard Replacement, Removing Fan: Schritt 5, Bild 2 von 3 NVIDIA SHIELD Portable Motherboard Replacement, Removing Fan: Schritt 5, Bild 3 von 3
    • Cooling is important for electronics, the last thing they want is to overheat.
    • Remove the two 7.3mm and four 8.4mm T5 Torx screws and disconnect the power cable.
    • Lift the fan free after the screws and cable are removed.
  6. NVIDIA SHIELD Portable Motherboard Replacement, Removing Logic Board: Schritt 6, Bild 1 von 3 NVIDIA SHIELD Portable Motherboard Replacement, Removing Logic Board: Schritt 6, Bild 2 von 3 NVIDIA SHIELD Portable Motherboard Replacement, Removing Logic Board: Schritt 6, Bild 3 von 3
    • The large board under the back case is the motherboard.
    • Using your T5 Torx screwdriver, remove six screws from the motherboard—two 7.3 mm screws and four 8.4 mm screws.
    • Simply pull gently on the edges of the board, wiggling it if necessary so as not to damage the ports at the top of the board.
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
Marc Perez
545 Reputation
2 Anleitungen geschrieben
USF Tampa, Team 1-1, Hickman Fall 2014 Mitglied von USF Tampa, Team 1-1, Hickman Fall 2014
USFT-HICKMAN-F14S1G1
4 Mitglieder
18 Anleitungen geschrieben
Ein Kommentar
Hay ich suche Ersatzteile für Nvidia shield Portable ich suche Board da wo kühler drauf ist , weil mein ist kaput gegangen :(
Konstantin Styngu - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 8
Insgesamt: 1,914
