Zum Hauptinhalt wechseln
Nabi 2 Screen Replacement
Was du brauchst
    1. Nabi 2  Screen Replacement, Nabi 2 Back Cover Removal: Schritt 1, Bild 1 von 3 Nabi 2  Screen Replacement, Nabi 2 Back Cover Removal: Schritt 1, Bild 2 von 3 Nabi 2  Screen Replacement, Nabi 2 Back Cover Removal: Schritt 1, Bild 3 von 3
      • Remove the rubber bumper from the tablet.
      Frag FixBot
      Kommentar hinzufügen
    2. Nabi 2  Screen Replacement: Schritt 2, Bild 1 von 2 Nabi 2  Screen Replacement: Schritt 2, Bild 2 von 2
      • With a PH00 screwdriver, remove the four outermost screws from the back of the tablet.
      Frag FixBot
    3. Nabi 2  Screen Replacement: Schritt 3, Bild 1 von 3 Nabi 2  Screen Replacement: Schritt 3, Bild 2 von 3 Nabi 2  Screen Replacement: Schritt 3, Bild 3 von 3
      • Carefully, insert a plastic opening tool into the seam of the device and begin gently prying the two plastic pieces apart.
      • Work the tool all the way around the device. Small plastic clips should release. If they do not, gently apply outwards pressure until the clips give.
      • Do not force the clips open, as they are fairly easy to break
      Frag FixBot
    1. Nabi 2  Screen Replacement, Screen: Schritt 4, Bild 1 von 3 Nabi 2  Screen Replacement, Screen: Schritt 4, Bild 2 von 3 Nabi 2  Screen Replacement, Screen: Schritt 4, Bild 3 von 3
      • Lay the tablet down flat and remove the yellow tape from the ZIF connector on each side
      Frag FixBot
    2. Nabi 2  Screen Replacement: Schritt 5, Bild 1 von 3 Nabi 2  Screen Replacement: Schritt 5, Bild 2 von 3 Nabi 2  Screen Replacement: Schritt 5, Bild 3 von 3
      • Using a spudger, slide the brown tab forward on each side of the connector
      • Slide until the connector is completely loose, then separate the screen from the bottom half of the tablet
      • If the screen is not working correctly, you will need to replace the entire display assembly
      Frag FixBot
Abschluss
7 weitere Personen haben diese Anleitung absolviert.
USF Tampa, Team 4-3, Lacy Spring 2016 Mitglied von USF Tampa, Team 4-3, Lacy Spring 2016
USFT-LACY-S16S4G3
4 Mitglieder
84 Anleitungen geschrieben
4 Kommentare zur Anleitung
Simple steps but very practical
myjamro - Antwort Teilen
Is the LCD glued to the front glass/digitizer?
Brent Huff - Antwort Teilen
It Worked Thank U So Much!!!
Sharon Thrash - Antwort Teilen
a piece that holds the screen ribbon cable in broke off my nabis motherboard while taking the screen off. I eventually did get the screen back on.
NabiGuy - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 18
Letzte 30 Tage: 63
Insgesamt: 8,648
