Zum Hauptinhalt wechseln
Nabi 2 Internal Speakers Replacement
Was du brauchst
    1. Nabi 2 Internal Speakers Replacement, Nabi 2 Back Cover Removal: Schritt 1, Bild 1 von 3 Nabi 2 Internal Speakers Replacement, Nabi 2 Back Cover Removal: Schritt 1, Bild 2 von 3 Nabi 2 Internal Speakers Replacement, Nabi 2 Back Cover Removal: Schritt 1, Bild 3 von 3
      • Remove the rubber bumper from the tablet.
      Frag FixBot
      Kommentar hinzufügen
    2. Nabi 2 Internal Speakers Replacement: Schritt 2, Bild 1 von 2 Nabi 2 Internal Speakers Replacement: Schritt 2, Bild 2 von 2
      • With a PH00 screwdriver, remove the four outermost screws from the back of the tablet.
      Frag FixBot
    3. Nabi 2 Internal Speakers Replacement: Schritt 3, Bild 1 von 3 Nabi 2 Internal Speakers Replacement: Schritt 3, Bild 2 von 3 Nabi 2 Internal Speakers Replacement: Schritt 3, Bild 3 von 3
      • Carefully, insert a plastic opening tool into the seam of the device and begin gently prying the two plastic pieces apart.
      • Work the tool all the way around the device. Small plastic clips should release. If they do not, gently apply outwards pressure until the clips give.
      • Do not force the clips open, as they are fairly easy to break
      Frag FixBot
    1. Nabi 2 Internal Speakers Replacement, Internal Speakers: Schritt 4, Bild 1 von 1
      • Using the soldering iron, detach the speaker's wires from the circuit board.
      Frag FixBot
    2. Nabi 2 Internal Speakers Replacement: Schritt 5, Bild 1 von 3 Nabi 2 Internal Speakers Replacement: Schritt 5, Bild 2 von 3 Nabi 2 Internal Speakers Replacement: Schritt 5, Bild 3 von 3
      • Using a Phillips PH 000 screwdriver, unscrew the two 3 mm Phillips #000 screws on each side of the speakers that hold the speakers in place.
      Frag FixBot
    3. Nabi 2 Internal Speakers Replacement: Schritt 6, Bild 1 von 1
      • Once the screws have been removed, remove the speakers from the device.
      Frag FixBot
Abschluss
USF Tampa, Team 4-3, Lacy Spring 2016 Mitglied von USF Tampa, Team 4-3, Lacy Spring 2016
USFT-LACY-S16S4G3
4 Mitglieder
84 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 28
Letzte 30 Tage: 51
Insgesamt: 1,130
