Einleitung
Warning: This guide requires desoldering/soldering.
This guide will walk you through the steps to removing the Nabi 2 motherboard. A motherboard replacement may be necessary if you experience total device failure. Before beginning this guide we recommend you follow all of the listed prerequisite guides.
Be sure to take extra care when removing the wifi antenna, camera and microphone from the Nabi 2 chassis, before lifting the motherboard out of the device.
Was du brauchst
With a PH00 screwdriver, remove the four outermost screws from the back of the tablet.
Carefully, insert a plastic opening tool into the seam of the device and begin gently prying the two plastic pieces apart.
Work the tool all the way around the device. Small plastic clips should release. If they do not, gently apply outwards pressure until the clips give.
Lay the tablet down flat and remove the yellow tape from the ZIF connector on each side
Using a spudger, slide the brown tab forward on each side of the connector
Slide until the connector is completely loose, then separate the screen from the bottom half of the tablet
If the screen is not working correctly, you will need to replace the entire display assembly
Desolder the battery connection and remove the battery completely
Note the color order for future replacemement
Using the soldering iron, detach the speaker's wires from the circuit board.
Using a Phillips PH 000 screwdriver, unscrew the two 3 mm Phillips #000 screws on each side of the speakers that hold the speakers in place.
Remove the seven 4 mm Phillips #000 screws with a PH#000 screwdriver
Eine weitere Person hat diese Anleitung absolviert.
