Zum Hauptinhalt wechseln
Nabi 2S Battery Replacement
Was du brauchst
  1. Nabi 2S Battery Replacement, Nabi 2S Disassembly: Schritt 1, Bild 1 von 1
    • Remove the red rubber case from the device.
    Frag FixBot
    Kommentar hinzufügen
  2. Nabi 2S Battery Replacement: Schritt 2, Bild 1 von 2 Nabi 2S Battery Replacement: Schritt 2, Bild 2 von 2
    • Make sure the screen is facing away from you and the back cover is facing you.
    • Using a Phillips #0 Screwdriver, unscrew the 3mm screws counter-clockwise in each corner of the plastic back cover. It will be a total of four screws. The smaller case on the back cover is attached to the main cover so it will not need to be removed.
    Frag FixBot
  3. Nabi 2S Battery Replacement: Schritt 3, Bild 1 von 1
    • Using the plastic opening tool, remove the case.
    • Removing the case will take a bit of effort and force. We recommend using two hands and if possible another person to help. It will require some gusto.
    • It is helpful to pry at the corners first to loosen the case.
    Frag FixBot
  4. Nabi 2S Battery Replacement: Schritt 4, Bild 1 von 1
    • After the back case is loosened, remove it from the device to change or access the battery.
    Frag FixBot
  5. Nabi 2S Battery Replacement, Battery: Schritt 5, Bild 1 von 3 Nabi 2S Battery Replacement, Battery: Schritt 5, Bild 2 von 3 Nabi 2S Battery Replacement, Battery: Schritt 5, Bild 3 von 3
    • Grasp the circuit connected to the battery via wires.
    • Slide the wires from the circuit to detach it.
    Frag FixBot
  6. Nabi 2S Battery Replacement: Schritt 6, Bild 1 von 2 Nabi 2S Battery Replacement: Schritt 6, Bild 2 von 2
    • After the circuit is detached, the battery will be easily removable.
    • Don’t rip the battery off of the board.
    • The battery is stuck with adhesive tape to the board.
    • Use a plastic opening tool to apply pressure to the battery and lift it up from the adhesive.
    Frag FixBot
Abschluss
4 weitere Personen haben diese Anleitung absolviert.
Marist, Team 1-4, Laflen Spring 2016 Mitglied von Marist, Team 1-4, Laflen Spring 2016
MARS-LAFLEN-S16S1G4
2 Mitglieder
10 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 24
Insgesamt: 1,105
