Einleitung
This guide will aid you in the process of removing the camera of the device. This is useful in replacing a broken or dis-functioning camera.
Was du brauchst
Make sure the screen is facing away from you and the back cover is facing you.
Using a Phillips #0 Screwdriver, unscrew the 3mm screws counter-clockwise in each corner of the plastic back cover. It will be a total of four screws. The smaller case on the back cover is attached to the main cover so it will not need to be removed.
After the back case is loosened, remove it from the device to change or access the battery.
Unscrew the circuit board from the motherboard by using a Phillips #0 screwdriver to unscrew the ten 4mm screws in a counter-clockwise rotation.
The camera is attached to the circuit board and then tucked underneath. Gently grip the part attached to the circuit board and pull it up and away from the circuit.
Gently slide the camera out from underneath the circuit board.
2 weitere Personen haben diese Anleitung absolviert.
