Zum Hauptinhalt wechseln
Nabi 2S Speakers Replacement
Was du brauchst
  1. Nabi 2S Speakers Replacement, Nabi 2S Disassembly: Schritt 1, Bild 1 von 1
    • Remove the red rubber case from the device.
    Frag FixBot
    Kommentar hinzufügen
  2. Nabi 2S Speakers Replacement: Schritt 2, Bild 1 von 2 Nabi 2S Speakers Replacement: Schritt 2, Bild 2 von 2
    • Make sure the screen is facing away from you and the back cover is facing you.
    • Using a Phillips #0 Screwdriver, unscrew the 3mm screws counter-clockwise in each corner of the plastic back cover. It will be a total of four screws. The smaller case on the back cover is attached to the main cover so it will not need to be removed.
    Frag FixBot
  3. Nabi 2S Speakers Replacement: Schritt 3, Bild 1 von 1
    • Using the plastic opening tool, remove the case.
    • Removing the case will take a bit of effort and force. We recommend using two hands and if possible another person to help. It will require some gusto.
    • It is helpful to pry at the corners first to loosen the case.
    Frag FixBot
  4. Nabi 2S Speakers Replacement: Schritt 4, Bild 1 von 1
    • After the back case is loosened, remove it from the device to change or access the battery.
    Frag FixBot
  5. Nabi 2S Speakers Replacement, Speakers: Schritt 5, Bild 1 von 2 Nabi 2S Speakers Replacement, Speakers: Schritt 5, Bild 2 von 2
    • Unscrew the circuit board from the motherboard by using a Phillips #0 screwdriver to unscrew the 4mm screws in a clockwise rotation.
    Frag FixBot
  6. Nabi 2S Speakers Replacement: Schritt 6, Bild 1 von 2 Nabi 2S Speakers Replacement: Schritt 6, Bild 2 von 2
    • The speakers are attached to the device via wires that are connected to a circuit. Grasp the circuit connected to the right speaker.
    • Slide the connected wires from the circuit to detach the speakers.
    Frag FixBot
  7. Nabi 2S Speakers Replacement: Schritt 7, Bild 1 von 3 Nabi 2S Speakers Replacement: Schritt 7, Bild 2 von 3 Nabi 2S Speakers Replacement: Schritt 7, Bild 3 von 3
    • Lift the circuit board to get better access for removing the speaker.
    • Grasp the speaker with your fingers and lift it from the plastic
    Frag FixBot
  8. Nabi 2S Speakers Replacement: Schritt 8, Bild 1 von 2 Nabi 2S Speakers Replacement: Schritt 8, Bild 2 von 2
    • Repeat steps 6 and 7 for the second speaker on the left side.
    • The circuit board should still be loose to remove the speaker.
    Frag FixBot
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
Marist, Team 1-4, Laflen Spring 2016 Mitglied von Marist, Team 1-4, Laflen Spring 2016
MARS-LAFLEN-S16S1G4
2 Mitglieder
10 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 28
Insgesamt: 526
