Einleitung
Make sure you are using the correct charging cable. Use the black cable, since the white cable can only be used for data transfer. Do not confuse the audio port with DC port. Test the power cable and nabi power adapter separately before attempting to fix DC port. If non of the above are causing the problem, replace the DC port.
Was du brauchst
Use your fingers to carefully peel them off the device to reveal the screws underneath.
Use a Phillips #1 screwdriver to remove the 9.5 mm screw in each of the four corners.
Insert a metal spudger into one of the openings and carefully pop the device open by applying a steady downward force.
Repeat for the other three openings.
Locate the white port that connects the back panel to the circuit board on the back of the display.
Carefully pull the plastic connector straight out.
Carefully lift up the aluminum foil tape with your fingers so that the ribbon connector reveals itself.
Firmly press the two switches located on the sides of the connector and disconnect the connector from its connections.
Use a plastic opening tool and carefully push it underneath the grey plastic case surrounding the ribbon cable.
Apply a downward force to carefully peel the grey plastic off of the metal display.
Locate the two cables running on both sides of the device found at the bottom side of the screen.
Carefully grab both sides of the white plastic piece with your fingers and gently pull directly upward.
Locate the battery charging port labeled "DC" on the side of the tablet .
Use a Philips #1 screw driver to unscrew the two silver 4.5 mm screws located on top of the circuit board.
Disconnect the white port with black and red cables from the circuit board with your hands.
Replace your circuit board with the new one.
Eine weitere Person hat diese Anleitung absolviert.
2 Kommentare zur Anleitung
Hi! Awesome! One question. Where do I get a new charging circuit board? Thanks!
Hi, have Nabi tablet, did you know where can I get the charging circuit board. T Q
