Zum Hauptinhalt wechseln
Nabi Big Tab HD24 Screen Replacement
Was du brauchst
  1. Nabi Big Tab HD24 Screen Replacement, Back Assembly: Schritt 1, Bild 1 von 1
    • Ensure that the tablet is facing you with the screen on the table.
    • Locate the four red rubber stops at the corners.
    Frag FixBot
    Kommentar hinzufügen
  2. Nabi Big Tab HD24 Screen Replacement: Schritt 2, Bild 1 von 1
    • Use your fingers to carefully peel them off the device to reveal the screws underneath.
    Frag FixBot
  3. Nabi Big Tab HD24 Screen Replacement: Schritt 3, Bild 1 von 1
    • Use a Phillips #1 screwdriver to remove the 9.5 mm screw in each of the four corners.
    Frag FixBot
  4. Nabi Big Tab HD24 Screen Replacement: Schritt 4, Bild 1 von 1
    • Flip the tablet over such that the screen is facing upwards.
    • Locate the the 4 small openings on the sides of the tablet.
    • There should be 2 on the bottom of the tablet, 1 on each side of the tablet viewing it from the front as if you were using it.
    • Do not confuse the openings with the charging port or the USB ports. The openings will be labelled with an icon of a small fan, the Nabi logo.
    Frag FixBot
  5. Nabi Big Tab HD24 Screen Replacement: Schritt 5, Bild 1 von 1
    • Insert a metal spudger into one of the openings and carefully pop the device open by applying a steady downward force.
    • Repeat for the other three openings.
    Frag FixBot
  6. Nabi Big Tab HD24 Screen Replacement: Schritt 6, Bild 1 von 2 Nabi Big Tab HD24 Screen Replacement: Schritt 6, Bild 2 von 2
    • Flip the device over so that the back assembly is facing you.
    • Use a plastic opening tool to carefully pry open the device from its hinges.
    • Take care when opening the device as there are cables running internally that are connected to both the front and the back assemblies.
    Frag FixBot
  7. Nabi Big Tab HD24 Screen Replacement: Schritt 7, Bild 1 von 2 Nabi Big Tab HD24 Screen Replacement: Schritt 7, Bild 2 von 2
    • Locate the white port that connects the back panel to the circuit board on the back of the display.
    • Carefully pull the plastic connector straight out.
    Frag FixBot
  8. Nabi Big Tab HD24 Screen Replacement: Schritt 8, Bild 1 von 1
    • Be careful of the aluminum foil tape, as it can easily rip.
    • Carefully lift up the aluminum foil tape with your fingers so that the ribbon connector reveals itself.
    • Do not try to pull the ribbon cables off the screen as there is a plastic piece surrounding the ribbon cables glued onto the metal display.
    Frag FixBot
  9. Nabi Big Tab HD24 Screen Replacement: Schritt 9, Bild 1 von 1
    • Firmly press the two switches located on the sides of the connector and disconnect the connector from its connections.
    • Leave the connector disconnected but still intact with the metal display.
    Frag FixBot
  10. Nabi Big Tab HD24 Screen Replacement: Schritt 10, Bild 1 von 1
    • Use a plastic opening tool and carefully push it underneath the grey plastic case surrounding the ribbon cable.
    • Apply a downward force to carefully peel the grey plastic off of the metal display.
    Frag FixBot
  11. Nabi Big Tab HD24 Screen Replacement: Schritt 11, Bild 1 von 1
    • Locate the two cables running on both sides of the device found at the bottom side of the screen.
    Frag FixBot
  12. Nabi Big Tab HD24 Screen Replacement: Schritt 12, Bild 1 von 2 Nabi Big Tab HD24 Screen Replacement: Schritt 12, Bild 2 von 2
    • Carefully grab both sides of the white plastic piece with your fingers and gently pull directly upward.
    • Do not pull from the red and black cable as it is not very sturdy and may come undone from the connector.
    Frag FixBot
  13. Nabi Big Tab HD24 Screen Replacement, Screen: Schritt 13, Bild 1 von 1
    • Take out the two black 4.5 mm screws with your Phillips # 1 screwdriver and remove the circuit board.
    • You want to remove this circuit board so you can remove the silver screw that the circuit board is blocking.
    Frag FixBot
  14. Nabi Big Tab HD24 Screen Replacement: Schritt 14, Bild 1 von 2 Nabi Big Tab HD24 Screen Replacement: Schritt 14, Bild 2 von 2
    • Remove each of the 6.5 mm silver screws located on the edges of the display's corners.
    Frag FixBot
  15. Nabi Big Tab HD24 Screen Replacement: Schritt 15, Bild 1 von 1
    • Use a heating gun to heat up the side up the side of the screen you want to pry open.
    • Evenly distribute the heat around the frame of the screen for optimal results.
    • Do not focus the heat on one specific point for long periods of time as this may cause the glass to crack.
    Frag FixBot
  16. Nabi Big Tab HD24 Screen Replacement: Schritt 16, Bild 1 von 1
    • Place several iOpeners along the sides of the screen that you are not heating up with the heat gun.
    • Spread them out around the device so the heat can evenly melt the adhesive on the screen.
    • Be careful when handling the iOpeners as they are hot and contain a gel that can burn skin if exposed from the packet.
    Frag FixBot
  17. Nabi Big Tab HD24 Screen Replacement: Schritt 17, Bild 1 von 1
    • Use the jimmy and stick it in between the screen and the frame and wiggle the jimmy around to try and loosen the glass screen from the frame.
    • It may take some strength and patience since the adhesive is still very sticky.
    Frag FixBot
  18. Nabi Big Tab HD24 Screen Replacement: Schritt 18, Bild 1 von 1
    • Once you create a space between the screen and the frame stick an i fixit pick in the crack to keep the crack open.
    • Keep inserting more picks every time you create some space, so eventually the screen will be completely separated from the frame.
    • Use the plastic opening tool to carefully remove the screen from the frame.
    Frag FixBot
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
Cal Poly, Team 4-1, Livingston Fall 2016 Mitglied von Cal Poly, Team 4-1, Livingston Fall 2016
CPSU-LIVINGSTON-F16S4G1
4 Mitglieder
14 Anleitungen geschrieben
6 Kommentare zur Anleitung
Where do you get parts for this thing tho
Nicholas Jones - Antwort Teilen
Any luck finding screen
daymiel Moore - Antwort Teilen
Where can you get this particular replacement screen?
Jay - Antwort Teilen
did you ever find a screen?
LushLeah - Antwort Teilen
Im looking for a screen too. Any luck on a referral?
Katherine Champion - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 28
Insgesamt: 3,999
