Einleitung
The Nabi Dream Table HD8 uses a durable propietary charging cable for charging. Over time, the charging connector or the cable itself can weaken, causing difficulties in recharging, system overheating or extended charging times. The individual component will require no more than five minutes to replace, but opening the device with be the most difficult and necessary prerequisite to the replacement.
Was du brauchst
Position the Nabi DreamTab onto a non-metallic surface so that the screen is facing towards the ceiling, and the DreamTab logo appears closest to you.
Remove the red silicone case from the Nabi DreamTab HD8.
Turn it upside down, ensuring the small black circular camera is in the upper left hand corner.
Remove the six 2.5 mm JIS #000 screws attaching the custom grid to the back panel.
Grasp one of the protruding squares and gently lift off the back plate. Place it aside for later reassembly.
Remove the three 3.5mm screws using the J-0 screwdriver attaching the back panel to the device.
Rotate the top of the device towards you so that the audio jack appears on the right side of the device.
Wedge the plastic opening tool between where the front and back case panels meet near the audio jack.
Pry the device open using moderate force until you hear a clicking sound. This is the sound of the clips unlocking.
Move along the perimeter of the entire device using the same prying motion to gradually separate the front and back panels.
Once the edges are open return to the same starting position next to the audio jack.
Once you've completed separating the front and back panels, place the device back onto the table, display facing downward and camera at the top left.
Lift off the back panel and rotate the device 180 degrees while the screen is facing down.
Eine weitere Person hat diese Anleitung absolviert.
Ein Kommentar
hi,
I would like to buy new E237212 but I can’t find it..can you help me?
