Was du brauchst
Remove the red rubber case from the device. This should come off with ease.
Turn the device so the screen is facing away from you.
Using a philips head, size #00, screwdriver, remove the screws in each corner of the plastic casing.(total of 4 screws)
After loosening the back cover, remove it from the device so you can get at the innards.
Replace the old battery with the new one
Solder the wires of the new battery into the pads on the motherboard
Once the wires are fully soldered, put the new battery back to the initial position
Close the case by putting the back cover back on the device
Once the back cover is on, screw in the four screws that you had taken off in the beginning
Put the red rubber casing back on.
If all the steps were followed correctly, the device should be fully closed and ready to go
4 weitere Personen haben diese Anleitung absolviert.
7 Kommentare
Thank you for sharing the idea ,but I need that NABI JR battery. So ,where from I can purchase it .
I have seen them on ebay but it's easier to find a Nabi 2 battery on ebay. The Nabi 2 battery is quite a bit larger but with a very minor mod to the Nabi Jr. the Nabi 2 battery will fit and give you a much longer run time from a single charge.
My old Nabi jr battery is a plug in with 2 reds 1 white and 2 black wires. My new Cameron sino battery is blue green red yellow black. What is the order to resolder them.
I have the same problem with the problem of the replacement battery not having the same wiring configuration or plug. Did you ever get this resolved?
