Zum Hauptinhalt wechseln
Nabi Jr Motherboard Replacement
Was du brauchst
  1. Nabi Jr Motherboard Replacement, Rear Case: Schritt 1, Bild 1 von 1
    • Remove the red rubber case from the device. This should come off with ease.
  2. Nabi Jr Motherboard Replacement: Schritt 2, Bild 1 von 1
    • Turn the device so the screen is facing away from you.
    • Using a philips head, size #00, screwdriver, remove the screws in each corner of the plastic casing.(total of 4 screws)
  3. Nabi Jr Motherboard Replacement: Schritt 3, Bild 1 von 1
    • Remove the device casing using a small plastic pry bar.
    • This might take a little bit of force to accomplish, don't be afraid to go at it with a little gusto.
  4. Nabi Jr Motherboard Replacement: Schritt 4, Bild 1 von 1
    • After loosening the back cover, remove it from the device so you can get at the innards.
  5. Nabi Jr Motherboard Replacement, Motherboard: Schritt 5, Bild 1 von 1
    • Use the Philips #00 screwdriver to remove the 5 screws from the motherboard
  6. Nabi Jr Motherboard Replacement: Schritt 6, Bild 1 von 1
    • De-solder the grey wire from motherboard
  7. Nabi Jr Motherboard Replacement: Schritt 7, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Use tweezers to peel off all yellow tape from the motherboard
    • Yellow tape is used in all locations where there is ribbon cable present.
  8. Nabi Jr Motherboard Replacement: Schritt 8, Bild 1 von 2 Nabi Jr Motherboard Replacement: Schritt 8, Bild 2 von 2
    • Remove all three ribbon cables from the motherboard by lifting up the locking tabs.
    • Pull black locking tabs up in opposite direction of ribbon cable to remove.
    • Use tweezers to pull the ribbon cable out of the locking tab's slot
  9. Nabi Jr Motherboard Replacement: Schritt 9, Bild 1 von 2 Nabi Jr Motherboard Replacement: Schritt 9, Bild 2 von 2
    • Lift motherboard to separate it the from the case shell.
Abschluss
Kaila Joy
86 Reputation
2 Anleitungen geschrieben
UMass Dartmouth, Team 4-3, Vijaybhaskar Spring 2015 Mitglied von UMass Dartmouth, Team 4-3, Vijaybhaskar Spring 2015
UMASSD-VIJAYBHASKAR-S15S4G3
3 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 5
Insgesamt: 1,180
