Was du brauchst
Remove the red rubber case from the device. This should come off with ease.
Turn the device so the screen is facing away from you.
Using a philips head, size #00, screwdriver, remove the screws in each corner of the plastic casing.(total of 4 screws)
After loosening the back cover, remove it from the device so you can get at the innards.
Use the Philips #00 screwdriver to remove the 5 screws from the motherboard
Use tweezers to peel off all yellow tape from the motherboard
Remove all three ribbon cables from the motherboard by lifting up the locking tabs.
Use tweezers to pull the ribbon cable out of the locking tab's slot
