Einleitung
Use this guide to replace the rear case on your Nabi Jr.
Was du brauchst
Remove the red rubber case from the device. This should come off with ease.
Turn the device so the screen is facing away from you.
Using a philips head, size #00, screwdriver, remove the screws in each corner of the plastic casing.(total of 4 screws)
After loosening the back cover, remove it from the device so you can get at the innards.
Fast fertig!
Abschluss
