Zum Hauptinhalt wechseln
Nabi Jr Rear Case Replacement
Was du brauchst
  1. Nabi Jr Rear Case Replacement, Rear Case: Schritt 1, Bild 1 von 1
    • Remove the red rubber case from the device. This should come off with ease.
  2. Nabi Jr Rear Case Replacement: Schritt 2, Bild 1 von 1
    • Turn the device so the screen is facing away from you.
    • Using a philips head, size #00, screwdriver, remove the screws in each corner of the plastic casing.(total of 4 screws)
  3. Nabi Jr Rear Case Replacement: Schritt 3, Bild 1 von 1
    • Remove the device casing using a small plastic pry bar.
    • This might take a little bit of force to accomplish, don't be afraid to go at it with a little gusto.
  4. Nabi Jr Rear Case Replacement: Schritt 4, Bild 1 von 1
    • After loosening the back cover, remove it from the device so you can get at the innards.
Abschluss
Tobias Young
27 Reputation
2 Anleitungen geschrieben
UMass Dartmouth, Team 4-3, Vijaybhaskar Spring 2015 Mitglied von UMass Dartmouth, Team 4-3, Vijaybhaskar Spring 2015
UMASSD-VIJAYBHASKAR-S15S4G3
3 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 9
Insgesamt: 409
