Zum Hauptinhalt wechseln
Nabi Jr Speakers Replacement
Was du brauchst
  1. Nabi Jr Speakers Replacement, Rear Case: Schritt 1, Bild 1 von 1
    • Remove the red rubber case from the device. This should come off with ease.
  2. Nabi Jr Speakers Replacement: Schritt 2, Bild 1 von 1
    • Turn the device so the screen is facing away from you.
    • Using a philips head, size #00, screwdriver, remove the screws in each corner of the plastic casing.(total of 4 screws)
  3. Nabi Jr Speakers Replacement: Schritt 3, Bild 1 von 1
    • Remove the device casing using a small plastic pry bar.
    • This might take a little bit of force to accomplish, don't be afraid to go at it with a little gusto.
  4. Nabi Jr Speakers Replacement: Schritt 4, Bild 1 von 1
    • After loosening the back cover, remove it from the device so you can get at the innards.
  5. Nabi Jr Speakers Replacement, Speakers: Schritt 5, Bild 1 von 1
    • The speakers are located near the top of the device close to the camera.
    • Using a desoldering tool, remove the speakers from the pads they are soldered to.
    • Note that the red wire is removed from the pad labeled with a "+" and the black wire comes from the pad labeled with a "-".
    • Solder the new speaker's wires onto their respective pads
Abschluss
Tobias Young
27 Reputation
2 Anleitungen geschrieben
UMass Dartmouth, Team 4-3, Vijaybhaskar Spring 2015 Mitglied von UMass Dartmouth, Team 4-3, Vijaybhaskar Spring 2015
UMASSD-VIJAYBHASKAR-S15S4G3
3 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 9
Insgesamt: 848
