Zum Hauptinhalt wechseln
Neato BOTVAC CONNECTED Filter Replacement
Was du brauchst
  1. Neato BOTVAC CONNECTED Filter Replacement, Battery: Schritt 1, Bild 1 von 1
    • Place the top of the Neato Botvac Connected against a flat surface.
  2. Neato BOTVAC CONNECTED Filter Replacement: Schritt 2, Bild 1 von 2 Neato BOTVAC CONNECTED Filter Replacement: Schritt 2, Bild 2 von 2
    • Remove the two 5.5 mm screws with a Phillips #2 screwdriver.
  3. Neato BOTVAC CONNECTED Filter Replacement: Schritt 3, Bild 1 von 2 Neato BOTVAC CONNECTED Filter Replacement: Schritt 3, Bild 2 von 2
    • Using the spudger, remove the panel covering the battery.
  4. Neato BOTVAC CONNECTED Filter Replacement: Schritt 4, Bild 1 von 3 Neato BOTVAC CONNECTED Filter Replacement: Schritt 4, Bild 2 von 3 Neato BOTVAC CONNECTED Filter Replacement: Schritt 4, Bild 3 von 3
    • Gently remove the connecting wires attached to the battery.
    • The wires are attached to the vacuum through a clip.
  5. Neato BOTVAC CONNECTED Filter Replacement: Schritt 5, Bild 1 von 1
    • Using the spudger, gently remove the battery from the device.
  6. Neato BOTVAC CONNECTED Filter Replacement, Filter: Schritt 6, Bild 1 von 1
    • Flip the cleaner around and locate the front panel.
  7. Neato BOTVAC CONNECTED Filter Replacement: Schritt 7, Bild 1 von 1
    • Gently remove the front panel by opening it with a spudger.
  8. Neato BOTVAC CONNECTED Filter Replacement: Schritt 8, Bild 1 von 2 Neato BOTVAC CONNECTED Filter Replacement: Schritt 8, Bild 2 von 2
    • Use the spudger to gently remove the paper filter.
Abschluss
Justin Silva
645 Reputation
5 Anleitungen geschrieben
UMass Dartmouth, Team 6-3, Botvin Spring 2023 Mitglied von UMass Dartmouth, Team 6-3, Botvin Spring 2023
UMASSD-BOTVIN-S23S6G3
4 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 5
Insgesamt: 75
