Zum Hauptinhalt wechseln
Neato BOTVAC CONNECTED Front Roller Brush Replacement
Was du brauchst
  1. Neato BOTVAC CONNECTED Front Roller Brush Replacement, Battery: Schritt 1, Bild 1 von 1
    • Place the top of the Neato Botvac Connected against a flat surface.
  2. Neato BOTVAC CONNECTED Front Roller Brush Replacement: Schritt 2, Bild 1 von 2 Neato BOTVAC CONNECTED Front Roller Brush Replacement: Schritt 2, Bild 2 von 2
    • Remove the two 5.5 mm screws with a Phillips #2 screwdriver.
  3. Neato BOTVAC CONNECTED Front Roller Brush Replacement: Schritt 3, Bild 1 von 2 Neato BOTVAC CONNECTED Front Roller Brush Replacement: Schritt 3, Bild 2 von 2
    • Using the spudger, remove the panel covering the battery.
  4. Neato BOTVAC CONNECTED Front Roller Brush Replacement: Schritt 4, Bild 1 von 3 Neato BOTVAC CONNECTED Front Roller Brush Replacement: Schritt 4, Bild 2 von 3 Neato BOTVAC CONNECTED Front Roller Brush Replacement: Schritt 4, Bild 3 von 3
    • Gently remove the connecting wires attached to the battery.
    • The wires are attached to the vacuum through a clip.
  5. Neato BOTVAC CONNECTED Front Roller Brush Replacement: Schritt 5, Bild 1 von 1
    • Using the spudger, gently remove the battery from the device.
  6. Neato BOTVAC CONNECTED Front Roller Brush Replacement, Front Roller Brush: Schritt 6, Bild 1 von 2 Neato BOTVAC CONNECTED Front Roller Brush Replacement, Front Roller Brush: Schritt 6, Bild 2 von 2
    • Remove the following screws with a Torx screwdriver:
    • Four 2.3 mm screws.
  7. Neato BOTVAC CONNECTED Front Roller Brush Replacement: Schritt 7, Bild 1 von 1
    • Gently remove the thin panel held by the four screws with a spudger.
  8. Neato BOTVAC CONNECTED Front Roller Brush Replacement: Schritt 8, Bild 1 von 1
    • Gently remove the two small wheels, and the axles attached to them.
  9. Neato BOTVAC CONNECTED Front Roller Brush Replacement: Schritt 9, Bild 1 von 1
    • Gently remove the panel that is on top of the front roller with the spudger.
  10. Neato BOTVAC CONNECTED Front Roller Brush Replacement: Schritt 10, Bild 1 von 1
    • Gently remove the front brush.
Abschluss
Justin Silva
645 Reputation
5 Anleitungen geschrieben
UMass Dartmouth, Team 6-3, Botvin Spring 2023 Mitglied von UMass Dartmouth, Team 6-3, Botvin Spring 2023
UMASSD-BOTVIN-S23S6G3
4 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 8
Insgesamt: 121
