Einleitung
In this guide you will be able to replace the side wheel of the Neato Botvac Connected. This wheel will need to be replaced if it is not moving the vacuum properly. The wheel will also need to be replaced if the vacuum decides to stop moving at all. Using this guide comes after having to remove the battery as a precaution.
Was du brauchst
Remove the following screws with a Torx screwdriver:
Four 2.3 mm screws.
Remove the following screws with a TR10 Torx screwdriver:
Six 2.3 mm screws.
Remove the screw that is directly attached to the wheel on the side using a Phillips #2 screwdriver.
Remove the two 2.3 mm screws on the front of the vacuum with a TR10 Torx screwdriver.
Remove the layer below the front bumper by pressing firmly on the two levers located nearby.
Eine weitere Person hat diese Anleitung absolviert.
